LabWindows/CVI
using attribute as pointer to IviRangeTable
I have an instrument with two types of sensors, with different characteristics. I would like to have two range tables, say:
static IviRangeTableEntry sensor1_frequency_tableEntries[] =
  {500e+6, 6e+9, 0, "FREQ", 0},
  {IVI_RANGE_TABLE_LAST_ENTRY}
static IviRangeTable frequency_table =
  IVI_VAL_RANGED,
        VI_TRUE,
        VI_TRUE,
        VI_NULL,
        sensor1_frequency_tableEntries,
and
static IviRangeTableEntry sensor2_frequency_tableEntries[] =
  {500e+6, 18e+9, 0, "FREQ", 0},
  IVI_VAL_RANGED,
        VI_TRUE,
        VI_TRUE,
        VI_NULL,
        sensor2_frequency_tableEntries,
Then when I initiate my IVI-driver I check what sensor is attached to the instrument. Now, to my question. I would like to set an attribute to point to the current range table. Something like this:
switch (type)
     case 1:
      checkErr ( Ivi_SetAttributeViInt32(vi, VI_NULL, BT4500B_ATTR_FrequencyRangePointer, VI_NULL, &sensor1_frequency_table));
       break;
     case 2:
      checkErr ( Ivi_SetAttributeViInt32(vi, VI_NULL, BT4500B_ATTR_FrequencyRangePointer, VI_NULL, &sensor2_frequency_table));
      break;
    default:
      break;
Does anyone know what (if any) type of attribute I have to use? Or any other ideas?
Thanks in advance
Fred Niemelä
System Engineer
Saab Aerotech
(3,089 Views)
What type of instrument do you have?  You can check the different specifications on the IVI Foundation website.
(3,072 Views)
