LabWindows/CVI
useDefaultTimer
I am trying to set the useDefaultTimer, but I can't seem to find it. I am
using CVI 5.5 on Win NT 4.0. I have read that it will be in the win.ini
for
Win 3.1. So I believe that it would be in the registry. I have not found
it
there. Where is useDefaultTimer located?
(3,214 Views)
Hey Greg. Did you get an answer to your question yet? It's been about six months now. Either all your hair is completely pulled out by now or you reached a statisfactory solution. Hopefully b.
I've only worked with the Timer control from the UIR under CVI 5.5. Are you wanting a system clock to time activities? Maybe more of an MFC thing?
Anyway, hope something has worked out for you.
Grant
Grant M. Johnson
Project Engineer
LECO Corporation
(3,214 Views)
