LabWindows/CVI
unsigned char array to callbackdata problem with memset
i'm going deeper into this argument and having some problem.
i have this structure
typedef struct t_evtype
	int addr;
	unsigned char line;
}s_evtype;
and defined a matrix variable
static s_evtype o_[32][8] = {0};
after i assigned this variable to the callbackdata
SetCtrlAttribute (panelOutputHandle, PANEL_OUT_TABLE, ATTR_CALLBACK_DATA, o_);
in the callback i've done this to read it
s_evtype (*o_)[32][8] = callbackData; // A pointer to an array of integers
and seems working but i have a problem when i have to use it.
i have a function that need as input a pointer to a s_evtype
void offout(s_evtype *evptr)
and when i pass the data like this
offout(o_[byte][bit]);
the pointer passed is wrong.
to get the correct pointer i have to do this
static s_evtype returnpointer(s_evtype o_[32][8], int byte, int bit)
	return o_[byte][bit];
and use a temp variable for the offout function...
i hope it's clear, i know is not a simple question
Davide Vittorio G. - TLGB S.R.L.
Italian SW Developer
Message 11 of 11
(834 Views)
