LabWindows/CVI
unreferenced function calls in CVI example
While looking at some example codes from CVI 8.0.1, I found there are functions that are neither defined in the example nor are part of the CVI built-in functions. For examples, in "Samples\utility\Threading\ThreadSafeVar\IncrementValue.c", the InitApp() calls
        InitilizeTsvGetSetAccess(),
        InitializeTsvPtrAccess(),
        SetTsvGetSetAccess(0), and
        SetTsvPtrAccess(0).
None of these functions are defined anywhere in the source and none of these can be found in the CVI Help. I think they have something to do with setting up the thread-safe variable, but I need some documentation. Does anyone know where to find these references? Thanks.
(3,410 Views)
If you look inside utility.h around the DefineThreadSafeScalarVar macro you should find some tricky code that accounts for the names you mention.
JR
(3,404 Views)
Thanks for pointing this out. Seem like they could at least put a comment in the example.
(3,401 Views)
