LabWindows/CVI
unrecoverable internal error
I am facing the followingf error when i am trying to build my project.Can you please help me to know what can be the issue.
unrecoverable internal error at 001B:105D9D18.
Labwindows/cvi will be aborted.
The funny thing is its working on a different machine.
I am not facing this issue when i am building my other projects.I suppose there can be some issue with callbacks.But i am not able to catch the issue.
Please provide me solution for this.
(3,067 Views)
PRS,
What version of CVI are you using? Is this happening only one project, or multiple project? What about examples? Has this always occurred since installation, or is this something that started recently? Has anything changed?
Could you post a log of the error. Run C:\Program Files (x86)\National Instruments\CVI2010\bin\ConfigCVILogging.exe and select all the logging message types and log to a file as shown below:
(2,988 Views)
I have the same problem with him.Can you help solve my problem? In the accessory, I paste my CVIDebugLog.txt. This problem just happens in some projects not all.
Thank you in advance! Waiting for your reply!
(2,503 Views)
