LabWindows/CVI
uninstall a CVI program
I'm using CVI 6.0 FULL and Win2K.
My question is when I install a CVI program, I have the option to run a .EXE after the instalation. Is it possible to do the same thing when I Uninstall my application ?, its because when the user run my app the first time I'm writing a lot of stuff in the Windows registry, I would like to remove all the data in that registry when I uninstall the apllication.
If someone know how....
Thank you,
(3,123 Views)
You definately can't do it with the Create Distribution Kit feature that is built into CVI. We are based on the MSI installer technology though, and you can take our installer and customize it in installer packages like InstallShield. I'm not sure if that can be done in MSI at all though, but if it could be done, it would require an installer package like InstallShield or Wise.
Best Regards,
Chris Matthews
(3,123 Views)
