LabWindows/CVI
under array bounds
what does "under array bounds" means ?. I've got that fatal runtime and can reproduce it but I don't understand what happend. I use a char pointer with 2 dll's.
Thank's for any pointer.
(4,089 Views)
Can you tell me what the full error message is? Sounds like you're running into a case where you performing some operation not within the allowed array bounds. You could be writing part the end of the string or dong something before it.
Bilal Durrani
NI
(4,073 Views)
it's concerning a char pointer.
void Test( char *psFile )
char sPath[MAX_PATHNAME_LEN],
sTest[50];
it's for psFile pointer but I don't understand . My pointer is good and points to sPath that have a goog path value.
After some functions I see that psFile is declared as 'under array bounds' in debug mode.
I've found only a solution : to declare bigger string variables after my pointer !. For example sTest[50] become sTest[150];
I've used Watch Variables possibility to catch modifications of my pointer but nothing seems to corrupt my pointer.
(4,062 Views)
Could you post a sample that lets me replicate what you are seeing? Some functions require a buffer of a specific size, which is why you might be running into this. But I'll be able to get a better idea if I could look at some code.
Bilal Durrani
NI
(4,052 Views)
