LabWindows/CVI
undefined symbol for 64 bit version only
it sounds like this simple question of the linker missing an undefined symbol, however...:
  • the project compiles fine in Debug mode, Debug64 mode, and also in Release mode - the linker complains only in Release64 mode
  • I deleted the cvibuild folder and rebuilt everything, same result
  • in the file where the variable seems unknown I have several variables defined as external, all work except this one, and all work if compiled as 32 bit executable. To be more precise, the declaration in file B is:
    extern int main_menubar_handle;
    extern double robust_statistics_resolution;
    Both variables are defined in the same file A. Only the second variable throws the linker error. Could it be a memory issue of the 64 bit linker?
The project has no external libs or dlls, just my own source code files. I am using CVI2020.
Any hints or suggestions?
Thanks!
(2,295 Views)
Dear All,
I have gained some more insight into this issue:
the linker error is gone if I remove the check mark "Enable OpenMP_support".
An undefined symbol error should not be caused by enabling this option, so now I tend to call it a bug in CVI.
Workaround:
  • don't build 64 bit executables or
  • don't use OpenMP or
  • don't use large projects
Unfortunately, for my project this is not an option, so I hope for a quick patch... Please, NI...
(2,236 Views)
In the mean time the bug has been reproduced at NI, thanks, Hamlet.
The bug report has the number 1244936
(2,231 Views)
Hi
(2,178 Views)
Hi Razvan,
thanks for looking into it and your suggestion, however, the variable is used in the file where it is defined.
Also, you should be able to have a look into the source code, I have sent it to NI for helping your colleagues reproduce the error. You might ask Hamlet where it went, he was the support engineer taking care of this case, but I also could send it to you via PM if needed.
(2,172 Views)
