LabWindows/CVI
timer (seconds or minutes)
Hi, I need some advice on the TIMER function. If I need a ONE minute interval, what factor must I mutiply to the factor in order to achieve that? The interval comes from an external input, i.e. it can change from ONE minute to maybe 5 minutes.
Thanks.
(3,288 Views)
I don't understand which 'factor' are you talking about.
Timer() is a function that returns the amount of seconds since the program started execution, so in order to achieve a some-minute interval you must:
1. save the initial Timer() value in a double variable
2.check at intervals the value returned by Timer()
The desired interval has expired when (initial-value - Timer()) gives a result greater than some-minute * 60.
Roberto
(3,288 Views)
Instead of the Timer() function, why not use a Timer control on your panel, and its corresponding callback? Then you can change the timer interval at any intervals you want, and call your other functions from inside that callback.
(3,288 Views)
"Craig Leidholm" ha scritto nel messaggio
news:5065000000050000006C540000-1007855737000@exchange.ni.com...
I agree with Craig: you can use setctrlattribute to set Timer interval with
a value calculated at run-time...
(3,288 Views)
