LabWindows/CVI
time domain graph
Hi folks!
I want to plot a time domain graph. I receive the data from a remote host, and I receive the time that the data was generated and the data itself.
The frequency of that data is variable.
The graph must have a fixed time slice (X axis). The graph must moves from right to left continuously.
Which object should I use? Does the labwindows have a graph object to plot it?
Thank you!
(3,410 Views)
Hi Oliveira, is your question related to this discussion? Have you tried Luis suggestions?
(3,407 Views)
The software that I am working in is event-oriented, so it is not a good approach to set a fastest rate and repeat the data that I plotted previously. Also, I don’t store the data locally; I just receive, plot and discard it.
That time, the solution suggested by Luis works, but now, I afraid that is not the best idea.
I hope that NI has an object that does it.
Thank you.
Message Edited by Oliveira on 01-28-2008 12:34 PM
(3,401 Views)
