LabWindows/CVI
threads, processes and dual core processors
we are using CVI and we want to use multithreading. The application shall run on a dual core processor, so the question came up if it is possible to define on which core the thread is running? Does anyone know if it is possible to start a progam, a process or a thread on a predefined core?
If this is not possible with CVI, is it possible directly with the Windows API?
Oliver
(3,301 Views)
it is possible using the Windows SDK functions "SetThreadAffinityMask()" and "SetProcessAffinityMask()". the cores on which you want the execution unit to run is specified using a bit mask. "GetProcessAffinityMask()" will tell you which bits are valid for your system. ("GetCurrentProcess()" and "GetCurrentThread()" will return the handle for the current process/thread).
beware that old Intel processors with HyperThreading are considered dual-core by this function.
(3,295 Views)
Accepted by topic author OZI
GREAT, thanks I will try it.
Greetings
Oliver
(3,292 Views)
