LabWindows/CVI
threading - ni6515
Is it possible to call DAQmxWriteDigitalLines  in different threads for different lines? or will every call have to be thread locked?
DAQmxCreateTask ("", &DOCARD);
DAQmxCreateDOChan (DOCARD, text, "",DAQmx_Val_ChanPerLine);
DAQmxStartTask(DOCARD);
DAQmxWriteDigitalLines (DOCARD, 1, 1, 10,
                                          DAQmx_Val_GroupByScanNumber,
                                          &DOArray[0],
 DAQmxStopTask(DOCARD)  ;
 DAQmxClearTask(DOCARD)
top ebony live sex cams: EbonySexCam | LiveEbonyCam | EbonyCam
(1,383 Views)
I believe DAQmx library is already multi-thread safe.
But the code snippet you provided does not look optimal. Do not create/clear tasks too often.
I usually create once at the beginning of my application and clear when exiting. That works for most of the projects.
Even Start/stop is not required too often.
So, create your tasks during initalization. Start when test/process starts and then read/write when required in whichever thread.
does not that scenario work for you?
S. Eren BALCI
IMESTEK
(1,347 Views)
