LabWindows/CVI
thread pool ownership
when shutting down a multithreaded application, the main thread schedules functions that will terminate the secondary threads, using PostDeferredCallToThread ( callback_function, callback_data, thread_id ) in a loop over all seconadry threads.
This works fine, and I can close the application as intended.
However, if I add another line to the loop, as recommended by the NI sample programs, CmtWaitForThreadPoolFunctionCompletion ( pool_handle, thread_function_id, OPT_TP_PROCESS_EVENTS_WHILE_WAITING ),
I receive an error message:
The function ID you passed is owned by the thread pool. This operation can only be performed on a function ID that you own.
This loop is initiated by the main thread, so how can the thread pool own a function ID?
I am using the pool handle that I obtained from the CmtNewThreadPool and not the default thread pool handle.
Thanks (and no more posts today)
Wolfgang
(4,109 Views)
Hi Wolfgang.
Keep in mind that callback_function you specify in the CmtWaitForThreadPoolFunctionCompletion() call will not execute until the thread becomes idle, so thread_function_id will not be valid.
Here is a simple approach that works for me:
int Shutdown;    // global variable
int myThreadPool;
int main (int argc, char *argv[])
  Shutdown = 0;
  CmtNewThreadPool(nThreads, &myThreadPool);
  // Signal threads - application is closing
  Shutdown = 1;
  CmtDiscardThreadPool(myThreadPool);  // Blocks until all threads in thread pool are idle
  return 0;
Each thread function (including those running in the default thread pool) includes lines similar to:
  while(!Shutdown && someOtherCondition)
    ProcessSystemEvents();
  return 0;
Colin.
Message Edited by cdk52 on 05-11-2009 10:07 AM
(4,093 Views)
Hi Colin,
sounds reasonable, but still this answer is confusing me because...
Recently, I have obtained a nice sample code from Roberto (here http://forums.ni.com/ni/board/message?board.id=180&message.id=41004#M41004)
which does exactly (?!) the same thing:
  PostDeferredCallToThread (QuitUICallback, 0, threadID);
  CmtWaitForThreadPoolFunctionCompletion (poolHandle, fnID, OPT_TP_PROCESS_EVENTS_WHILE_WAITING);
and it worked just fine...
Wolfgang
(4,075 Views)
Hello Wolfgang.
My apologies. When you wrote "...the main thread schedules functions..." I assumed that you were calling CmtScheduleThreadPoolFunction() or CmtScheduleThreadPoolFunctionAdv() - I ignored "...using PostDeferredCallToThread()...".
I looked at the modified MultiPanel sample provided by Roberto. If your code is similar in structure, I can see no reason why it should not work as you expect.
Does your code include any calls to CmtReleaseThreadPoolFunctionID()? I imagine that if you call CmtWaitForThreadPoolFunctionCompletion() after the function ID has been released, you will generate an error.
Good luck.
Colin.
(4,060 Views)
Hi Colin,
Thanks for suggesting to check for CmtReleaseThreadPoolFunctionID. Indeed I had such a call, but even if commenting it out the error remains the same. By the way, when calling CmtReleaseThreadPoolFunctionID instead of CmtWaitForThreadPoolFunctionCompletion, I receive the same error...?? This seems to suggest that something with my pool handle is wrong, but I make use of it only once, when starting the secondary threads from the primay threads using
CmtScheduleThreadPoolFunctionAdv ( pool_handle, thread_function, thread_function_data, csi_process_class, callback_function,
( EVENT_TP_THREAD_FUNCTION_BEGIN || EVENT_TP_THREAD_FUNCTION_END ), 0, RUN_IN_SCHEDULED_THREAD, NULL )
I can't see anything wrong here...
Wolfgang
(4,053 Views)
