LabWindows/CVI
textbox problem
we created a textbox which should contain the following:
" wert = [int] : [char] "
How can we put in an integer, though the textbox only excepts a character or pointer to char?
And how can we manage to combine a character and an integer to a string?
Hope, someone can help us ...
Thanks.
(3,531 Views)
You can use the standard ANSI C function sprintf to format and append any data type into a string. Something like:
char buffer[100];
int number = 5;
char character = 'a';
sprintf(buffer, "wert = %d:%a", number, character);
That would give you a string in buffer that reads "wert = 5:a".
Best Regards,
Chris Matthews
(3,531 Views)
minor correction:
sprintf(buffer, "wert = %d:%c", number, character);
but Im just being picky
Bilal Durrani
NI
Bilal Durrani
NI
(3,531 Views)
Try this:
char line[100], your_char_variable;
int your_int_variable;
sprintf(line," wert=[%d] : [%c]",your_int_variable,your_char_variable);
ResetTextbox(panel,txtctrlid,"line");
"m_schulze" wrote in message
news:50650000000800000044580000-1027480788000@exchange.ni.com...
> string?
> Thanks.
(3,531 Views)
