LabWindows/CVI
table crashes program
I have a problem with a table control.
I display in this control 500 rows; each record contains about 10 fields (string, float and int).
During the tests in debug mode the program works correctly; When I build the project and run the .exe file, the program crashes when it ends to load the values into the table.
So I have two differents behaviours in debug and release mode. What can I do?
I tried to:
- use SetCtrlAttibute (... , ATTR_CTRL_VAL, ...) to increase speed (it was slow before)
- set the table not visible during the update proce
Can you help me?
Thank you!
PaoloP
(3,743 Views)
PS. I use CVI 7.1.1
(3,737 Views)
Hi Paolo,
so the problem shows up when working with the release executable? I'm going to investigate deeper and I'll reply to you as soon as possible.
Fabio
Fabio M.
NI
Principal Engineer
(3,725 Views)
Hi Fabio, the problems appears only when working with the release executable.
I think the problem is related to the dimension of the data shown: if I displlay few records there are no problems; if I display 500 records the program crashes.
Best regards, Paolo
(3,699 Views)
