LabWindows/CVI
tab control
I am trying to change the label on a tab control in developer mode. It (CVI9) won't allow me and displays message:
'Attempted to make an inoperable control the active control'
Has anyone else run into this problem?
-John
Message 1 of 9
(6,881 Views)
What kind of control are you trying to change?  Does this happen if you create a new project and create another control of the same type?
Mark E.
Message 2 of 9
(6,849 Views)
It is the label on the tab page of a tab control.
Message 3 of 9
(6,840 Views)
Are you trying to change the label programmatically or manually?  If programmatically, could you share the line(s) of code you're using?
Mark E.
Message 4 of 9
(6,802 Views)
I can change the tab labels programmatically but cannot change them in developer mode; I also cannot move the tabs.
Message 5 of 9
(6,796 Views)
Mark E.
Message 6 of 9
(6,763 Views)
I can create a new project with a tab control and it behaves correctly.
Message 7 of 9
(6,744 Views)
I apologize for not understanding what you are saying.  I've tried very hard to reproduce the behavior you are seeing, but I can't.  I need a very specific list of steps that you follow, preferably with screenshots, describing the actions you take to get this error message.  Thank you!
Mark E.
Message 8 of 9
(6,701 Views)
I see this error in a TestStand CVI user interface when the focus has been on a control (say an edit control) then the user right clicks on a sequence to run it - at which point the TestStand engine attempts to display a new execution. However the aforementioned CVI error is generated.
To circumvent this, it seems the developers wrap the offending UI calls like this:
  SetBreakOnLibraryErrors (0);
  error = GetPanelAttribute (GetTxPanel(), ATTR_VISIBLE, &RxPanelVisible);
  error = GetPanelAttribute (GetTxPanel(), ATTR_VISIBLE, &TxPanelVisible);
  SetBreakOnLibraryErrors (1);
Hope this helps,
Ronnie
Message Edited by Believer on 05-12-2010 09:58 AM
Message Edited by Believer on 05-12-2010 10:00 AM
TestStand 4.2.1, LabVIEW 2009, LabWindows/CVI 2009
Message 9 of 9
(6,219 Views)
