LabWindows/CVI
system tray notification
How can I add system tray notifications? Just like this.
Message Edited by Sheetal on 01-12-2007 04:38 PM
Thanks.
CVI 2010
LabVIEW 2011 SP1
Vision Builder AI 2011 SP1
(3,701 Views)
Sheetal,
CVI does not have any of this sort of functionality built into it, but I am sure using the Windows SDK, you can accomplish this task. Here are a couple of links that should be able to help you out.
KnowledgeBase: How Do I Use the Windows SDK in CVI?
MSDN.com - Windows API Functions by Release
Though I am not positive as to this function's existence (since I am not aware of every Windows API function) if it is an available function, it would be located in the Windows API for sure.
Brandon Vasquez | Software Engineer | Integration Services | National Instruments
(3,657 Views)
Howdy Sheetal,
I am not exactly sure of what your end goal is in terms of "notifications", but there are several functions in LabWindows/CVI that work with the Windows System Tray.
LabWindows/CVI provides the functionality to install a system tray icon.  Refer to the trayicon shipping example in the <CVI>\samples\toolbox\ directory.
You can use the the InstallSysTrayIcon function to install a user-defined icon in the Windows System Tray.  With this function, you can install a system tray icon, install a callback function that receives mouse events, add tooltip text, etc.  You can even use the AttachTrayIconMenu and the InsertTrayIconMenuItem functions to attach a right-click pop-up menu to the icon.
These functions are located in the Programmers Toolbox (In the Library Tree, navigate to the path Libraries >> Programmers Toolbox >> User Interface Utilities >> System Tray Icons).
Hope this helps!
Best Regards,
Jonathan N.
(3,652 Views)
