LabWindows/CVI
system slows down during development
I currently need to reboot my PC twice a day when I do development using LabWindows/CVI 6.0. The PC becomes slower and slower (reaction, screen refresh...). I use WinXPpro german; the same behaviour is on my collegues PC (Win2k pro german). There is no significant increase of processor load, no increase of memory usage. I reinstalled my PC - same... Any ideas?
E. Sommerauer
(3,536 Views)
I'm pretty sure this couldn't have anything to do with CVI. How much memory do you have? It could be that your machine is moving into virtual memory after executing for a while which uses the hard drive and is much slower. Also, have you defragmented your hard drive lately?
Best Regards,
Chris Matthews
(3,536 Views)
Memory: 256 MB, drive defragmented. I'll check the virtual memory, but the task manager displays an overall memory usage (the graph display) of about 180 - 200 MB.
It happens mostly when I start my application from within the IDE often during development - simply editing does not seem to be a problem.
I'll keep you informed on the virtual memory issue. Thanks.
(3,536 Views)
I have had this exact problem before. I checked all of my memory allocation/deallocation and found that I had a small memory leak. By the end of the day, my PC was useless and I had to restart Windows. Check ALL of your memory allocation and make sure that it is being freed. Even the smallest leak can shut down a PC.
(3,536 Views)
Bthorp is right, memory leaks could be the cause of this. There is a function called CVIDynamicMemoryInfo in the utility library that can help you track down a leak. It will show you all of the dynamically allocated (malloc, calloc, etc) buffers that are existing in your program.
Best Regards,
Chris Matthews
(3,536 Views)
