LabWindows/CVI
syntax coloring text editor
I am designing my own editor in lab windows CVI.
I want to use syntax coloring for the source code text.
Use of different colors for tokens,keywords constants etc. what control should i use and how should i go about programming my application.
with gratitude
vivek $
(3,363 Views)
Using a UIR listbox ?
> application.
If so, there are color escape codes you can insert in the text. I remember seeing it discussed
many times before. ..\samples\userint\listdelx.prj' contains the info needed.
A simple parser should be able to do that.
Guillaume Dargaud
http://www.gdargaud.net/
"It's a little-known fact that the Y1K problem caused the Dark Ages."
(3,363 Views)
Seems to me that the list box is your best bet for this application. I would suggest that every time the user types a space key you run that line through your parser to add the coloring tokens. You should also keep a copy of the data without any of the coloring tokens to be able to easily compile the file latter on.
Good luck with your project.
Juan Carlos
(3,363 Views)
