LabWindows/CVI
stylesheet in function panel
Hallo everybody,
how is it possible to use a html stylesheet-file (.css) to format the function panel help.
Following code does run:
<html>
<head>
  <style type="text/css">
      body { font-size:10pt;
             line-height:12pt;
             font-family:Courier;
  </style>
</head>
<body>
    description
</body>
</html>
But the same example with outsourcing code doesn't work:
<html>
<head>
  <link rel="stylesheet" type="text/css" href="MyStyle.css">
</head>
<body>
    description
</body>
</html>
What possibility does exist to use a extern file for the style? I don't want to change every help text if the style change.
Please tell me a solution. Thanks.
Greetings
(3,830 Views)
Hello balthamos,
I tried to reproduce the problem you described and found out that *.css stylesheets applied to the HTML function panel help and finally got this working:
Used the following HTML ...
<html>
<head>
<link rel="stylesheet" type="text/css" href="../test.css"/>
</head>
<body>
<b>test</b> Hello
</body>
</html>
and the following CSS ...
BODY {
 background-color: #000000;
 font-family: Arial, Helvetica, Verdana, sans-serif;
 color: #FFFFFF;
 font-size:12px;
Specification of the path seems to be a bit weird, as not all path specificatons are valid, although working in IE.
Hope this helps,
C.L. - National Instruments Germany
(3,793 Views)
Forgot to tell you to place the test.css in the following path:
Drive:\..\CVIxx\bin
C.L.
(3,790 Views)
Great, that works!
Best regards
(3,692 Views)
