LabWindows/CVI
structure
Hi, I need some help here. I have 2 structures, the second one is used in the first one. How can I get the elements of the second structure.
typedef struct tagLayer3LongLatencyInfo
unsigned long ulMinimum; /
unsigned long ulMaximum; /
U64 u64Total; /
unsigned long ulFrames;
} Layer3LongLatencyInfo;
typedef struct tagU64
unsigned long high;
unsigned long low;
} U64;
How can I specify or get u64Total here
Here is what I tryied.
void getLat(int x,int y, int z)
 Layer3LongLatencyInfo INFO;
 U64 ELEMENT;
 INFO.ulMinimum =0 ;
 INFO.ulMaximum =0 ;
 // how can I specify u64Total
 INFO.ELEMENT.u64Total; // NOT SURE HERE
// Some codes.......
(3,369 Views)
Elements in nested structures can be accessed with the selection operatore in the same way as other element structures.
In your case, you do not need to declare a U64 variable in the function: "nephew" elements are accessed by using INFO.u64Total.high and INFO.u64Total.low
(3,362 Views)
Thank you.
(3,349 Views)
