LabWindows/CVI
string to function call
I would like to call any function from an external source command string such as:
example : "anyfunc(2.3,5.5,"hello");
How can I do this in CVI? It should be able to call any external module functions as well.
(3,080 Views)
You can't do this for a statically linked function. The only way to work around this would be to set up a lookup table for the function name that would give you the function pointer, but dealing with arguments could be complicated.
If you are calling this function in a DLL, then you can use GetProcAddress on the function name to retrieve a function pointer, then call it with that pointer.
Best Regards,
Chris Matthews
Measurement Studio Support Manager
(3,080 Views)
