LabWindows/CVI
string array from .net wrapper function
I am using a wrapper function created by the .net controller for a C# dll.  A function of the dll has a string array argument in C#.  The function prototype of the wrapper function for this string array turns out to demand a
char ***array
for this parameter.  This seems to be different from what CVI Help's sample code demonstrates i.e.
// in C#
public double[] MyArrayMethod(string[] array, ...
// in CVI
char * array[]={"a", "b"};
MyArrayMethod(aHandle, array, ...
I tried it anyway and got an error message saying
Type error in argument 2 to `MyArrayMethod'; found 'pointer to pointer to char' expected 'pointer to pointer to pointer to char'.
How should I declare and initialize this variable to use the wrapper function?
(4,954 Views)
An array of strings is often passes as
char [numStrings][maxSizeOfStrings]
or the array of strings is condensed into one string and passed with an array of offset values so the function can parse the string.
Let us know if the char [][] works for your function or if you needed to go about it the long way and change the function call and only pass one large string.
(4,913 Views)
Thanks for the reply.
I tried
char *array[2][10]={0};
and got
"found 'pointer to array 10 of pointer to char' expected 'pointer to pointer to pointer to char'."
(4,910 Views)
try char array [][] and not char *array[][].
Also if it is expecting a "pointer to pointer to poiner to char" it might be looking for char **array[] or even char***
If you are still having trouble, post some code (the dll you are calling and the .c file that calls it) so we can take a look at it.
(4,908 Views)
