LabWindows/CVI
strcpy malloc problems??
#define DB_NAME ";DB="
#define DSN_CHAR "DSN"
#define DSN_PRELUDE "DSN="
#define PROMPT_USR_PWD ";DLG="
char *ConDB_Name,
*TablesName,
*DB_Path_Name,
*DB_string,
DB_Tables_Name[51];
DB_Source_Name[81];
ConDB_Name = malloc(strlen(DSN_PRELUDE) + strlen (DB_Source_Name) + strlen(DB_NAME) + strlen(dirname) + strlen(PROMPT_USR_PWD) + 20);
strcpy(ConDB_Name, DSN_PRELUDE);
strcat(ConDB_Name, DB_Source_Name);
strcat(ConDB_Name, DB_NAME);
strcat(ConDB_Name, dirname);
strcat(ConDB_Name, PROMPT_USR_PWD);
after the strcpy(ConDB_Name, DSN_PRELUDE); command ConDB_Name should be "DSN=" but I am getting "24" instead... probably garbage.
I've tried this code on my laptop and works fine but
does not on my desktop.
TIA-
(3,853 Views)
The chunk of code you posted isn't complete. Somewhere else you must declare and initialize dirname, and initialize DB_Source_Name. If you have only declared but not initialized a string, you don't want to use it with strcat().
The code you posted also has a mistake which I assume is a typo (otherwise the compiler would have caught it): the line DB_Tables_Name[51] should end in a comma (not a semi-colon) to continue the char declaration to DB_Source_Name.
If your variables DB_Source_Name and/or dirname change between malloc() and strcat(), you should use sizeof() in malloc(), not strlen(). sizeof(DB_Source_Name) will always return 81. strlen(DB_Source_Name) may return a lower number (including 0) if DB_Source_Name doesn't use up the full 81 bytes.
If code works on y
our laptop but not on your desktop, something else (other than malloc) must be different. Are you running the debug configuration on one and the release configuration on the other?
(3,853 Views)
Sorry for the typos... you are correct!
I went ahead and changed in malloc(); to sizeof(DB_Source_Name) and sizeof(dirname); but I still get error at strcpy(ConDB_Name, DSN_PRELUDE); Before I step in/over DSN_PRELUDE = "DSN=" and ConDB_Name = a long string 4 repeating strange characters. After the strcpy, ConDB_Name = "24" instead of "DSN="?
I think I can get it to work without using malloc(); and declaring from *ConDB_Name to ConDB_Name[256];
Thanks-
(3,853 Views)
OK, I think I have lost my mind!! This is what I did:
in seperate .h file:
in .c file:
int CVICALLBACK InsertCallback (int panel, int control, int event,
void *callbackData, int eventData1, int eventData2)
static char *cstart = DSN_PRELUDE;
switch (event)
when I check the value of cstart it equals "24"!!
when I go back and change the #define's 'N' character in "DNS=" to any other character, I get cstart = DSN_PRELUDE!!!!!!! I verified on my laptop and this does NOT happen!
(3,853 Views)
