LabWindows/CVI
static library with function panel embeded into
I created a static library .lib which uses inifile.fp. I am using this library in some other project to create a  dll. Unless i include the inifile.fp along with the library i am not able to link the project.
Is there a way to to avoid adding the function panel in my second library?
Reagrds,
Ramjee
(3,135 Views)
Just include the source file for the fp, inifile.c, in your static library build.
You'll typically find it in C:\Program Files\National Instruments\CVInn\toolslib\toolbox.
Martin
Certified CVI Developer
(3,127 Views)
