LabWindows/CVI
sql toolkit for Windows XP x64
I'm using LabWindows 8.5.1 with SQL Toolkit 2.0.6.
Is there an upgrade or add-on for this toolkit version that will let me use my applications on Windows XP x64 machines.
I have installed and configured the MySQL x64 connector to my target machines.
I have no problems with my standard Windows XP machines.  I have to copy the file cvidb32.dll to each c:\WINDOWS\System32 folder.
Is there an equivalent cvidb64.dll file that I can use on the x64 machines?
I've seen that toolkit version 2.1 is compatible with Vista x64.  Will this also work with XP x64?
(3,265 Views)
Mike,
None of our software is officially supported on XP 64, if you really need a 64 bit OS, I would recommend Vista. Are National Instruments Products Compatible with 64-bit Windows XP x64 Operating Systems?
Richard S -- National Instruments -- (former) Applications Engineer -- Data Acquisition with TestStand
(3,244 Views)
