LabWindows/CVI
sound acquire
thank you very much. I changed my sound card and now it works
Message 11 of 13
(1,688 Views)
hello
I tried the projects and I would have a couple of questions
what the "handle" does?
I would like to send sound for 20sec max.
how would it be possible to control it through User Interface with 3 buttons?
for example:I press a button and the recording begins, the second button will end the recording, end the third button replays the the recorded sound
for example: Start, Stop and Replay buttons
would be able to help me with this?
Message 12 of 13
(1,437 Views)
Hello Peti,
1. Unfortunately, I have used a generic and undescriptive name "handle" to identify the audio device that you are using in your program. "audioDevice" would have been a better choice. You have pass this reference to all the waveIn/Out functions so that the operating system knows which audio device you want to work with.
2. My example plays a sound for one second. Either you play this sound 20 times in a for-loop, or you can generate a longer waveform for the entire 20 seconds. In the latter case, you will have to increase the sample buffer sizes and modify the for-loops that generate the signal accordingly.
3. If you want to record waveforms of arbitrary length, you have to figure out where to store the data. One option is to malloc a large memory buffer that you will gradually fill up. You can expand the memory buffer with realloc when necessary, but this will become rather slow as the memory buffer grows larger. Another option is to write the audio data to disk with the TDMS library for high-performance streaming of data.
Main program: create a memory buffer to hold one second of waveform data
create a suspended async timer with a loop rate of 1 second
(async timers give better accuracy than UI timers)
Start button: delete any existing TDMS files with previous recordings (if you want)
open a new TDMS file for recording
  resume the async timer
Stop button: suspend the async timer
close the TDMS file
Replay button: reopen the TDMS file
read the audio data from the TDMS file in one second increments
send the data to the audio output device for playback as in my example
  Async Callback: retrieve audio input from the audio device as in the example program
append the audio data to a TDMS file
You can find more information about TDMS in samples/TDM Streaming/...
Peter
Message 13 of 13
(1,395 Views)
