LabWindows/CVI
smooth panel resize
I would like to arrange the controls on my panel while the panel is being resized. Unfortunately, the panel's callback function is only called (with event set to EVENT_PANEL_SIZE) after the panel has been resized (when the user releases the mouse button). When the user left-clicks on the edge of the panel to start resizing it, the panel's callback function is not executed, so I can't use it. Is there any way to catch this event?
Wim
(3,828 Views)
Hi Wim, I'm afraid you cannot get such an information on the CVI side. Instead, you need to process some Windows message in a specifica callback installed via InstallWinMsgCallback function in the Programmer's Toolbox. I made some test with this code:
1. In the main function install the callback for processing WM_SIZING Windows event:
 err = InstallWinMsgCallback (panelHandle, WM_SIZING, sizingCbk, VAL_MODE_INTERCEPT, NULL, &WHandle);
2. Here a skeleton of the callback that is called during windows sizing:
int CVICALLBACK sizingCbk (int panelHandle, int message, unsigned int* wParam,
  unsigned int* lParam, void* callbackData)
// Function to process sizing of the window
 switch (*(int*)wParam) {
  case WMSZ_RIGHT: DebugPrintf ("Sized on the right\n"); break;
  case WMSZ_LEFT:  DebugPrintf ("Sized on the left\n");  break;
 return 1;   // According to SDK documentation function must return TRUE
With the same method you can process other events such as WM_MOVING. The same callback can be installed for several messages since it receives messageID in its secon parameters. I don't know how often the function is called, but it is *very* often: you may need to process lParam values (which points to a structure that holds window boundaries) to determine when to adjust controls position, otherwise you may suffer a significant overhead on the system.
I hope this helps
Roberto
Message Edited by Roberto Bozzolo on 04-26-2006 05:56 PM
(3,815 Views)
Hello Roberto,
thanks a lot for the information, I'll let you know if I can implement this successfully Smiley Happy
(3,810 Views)
Hello Roberto, it works great. I never used the InstallWinMsgCallback function. Seems like you can use it for a lot of things...
(3,784 Views)
