LabWindows/CVI
smart card reader
Hi all
I am using a pcb that switches an on board smart card communications between two dummy smart cards.  One is fitted to a device and the other is fitted to a USB smart card reader.
I have written some code that works fine once, but fails after that unless I either pull out the USB lead (works) or the dummy smart card reader (brings up a prompt to try again etc).
I am trying to figure out if it is possible to fix this issue with code rather than extra hardware or mods.
Sudo code:
Inside a Callbackcommand:
DeleteFile *.* if ==0
then say pass
CopyFile *.* if ==0
then say pass
Switch lines to other dummy card
run code etc
Switch lines to smart card reader
finish
The errors on DeleteFile/CopyFile are either 5 or 6.
The smart card reader does not like the comms severed with out the internal switch being released.
I think I may need to close the mass storage device and reopen it maybe?  Any ideas please?
(3,613 Views)
maybe  getdrivetype will work?
(3,611 Views)
Firstly, welcome to the NI Discussion Forums and apologies for the late reply.
Have you been able to make any progress with this issue?
I am a little unclear as to exactly what you are doing. Would it be possible for you to clarify the following:
How does the PCB switch communications between the two devices?
Is this a custom PCB?
You mention that one communication connection is fitted to a device - what device is this?
Chris (CLED, CLA, CTA)
Applications Engineering Specialist
(3,555 Views)
