LabWindows/CVI
simultaneous acquisition
I'm acquiring torque from an analog input on my board by means of the output of an encoder. The encoder reads the movement of a stepping motor and inputs my counter (used as channels A and B of a quadrature encoder): at every increment of the counters, I read a torque value. In this way I get an array in wich each torque value is related to an angle. Now I need to get, by keeping this acquisition active, another acquisition of the same torque, but related to time. The idea is to start an asyncronous acquisition at the time x and then to start monitoring counters for acquiring the torque values at well defined angles. When this acquisition stops itself, I force the first acquisition to terminate. How can I realize the first asyncronous acquis
ition? I add a file with some rows of my application regarding the existing syncronous acquisition with the counters.
Thanks!"
(3,271 Views)
Based on your sample code and my understanding of your question. I'll suggest you look at the possibility of capturing time within the for-loop after or before calling AI_READ? This can be captured into an array and you can later reconcile it with torque later.
(3,271 Views)
