LabWindows/CVI
several 3D plots on the same graph
hi,
I'm using the library CW 3D graph.
I would to plot several 3D curves on the same graph : is it possible?
To draw my curves, I use : CW3DGraphLib__DCWGraph3DPlot3DMesh(graphHandle,NULL,xVt2,yVt2,zVt2,CA_DEFAULT_VAL)
thanks..
Adeline
Message 1 of 13
(5,919 Views)
according to this document mutliple plots are possible.
Message 2 of 13
(5,913 Views)
thanks, I read it...
but I don't find how to do it...
 bye
Adeline
Message 3 of 13
(5,882 Views)
You should be able to do it just like any other graph by "Plotting" additional curves.  And you would keep track of it with a plot handle returned.
i believe the functions are:
CA_VariantSet1DArray (&var_theta, CAVT_DOUBLE, cell_cnt, &theta_array);
CA_VariantSet1DArray (&var_phi, CAVT_DOUBLE, cell_cnt, &phi_array);
CA_VariantSet1DArray (&var_mag, CAVT_DOUBLE, cell_cnt, &mag_array);
CW3DGraphLib__DCWGraph3DPlot3DCurve(graph_handle,NULL,var_phi,var_theta,var_mag,CA_DEFAULT_VAL)
of course you can use x,y,x coordinate system as well.
Message 4 of 13
(5,873 Views)
 ok
for the moment, I do like that....
fenetre_3D = LoadPanel (fenetrePrinc, "interfac.uir",REP_G_3D);
GetObjHandleFromActiveXCtrl (fenetre_3D,REP_G_3D_GRAPH3D_PIECE , &graphHandle);
CW3DGraphLib__DCWGraph3DGetPlots (graphHandle, NULL, &plotsHandle);
CW3DGraphLib_CWPlots3DItem (plotsHandle, NULL, CA_VariantInt(1),&plotHandle);
DisplayPanel(fenetre_3D);
CA_VariantSet1DArray(&xVt, CAVT_DOUBLE,nombre,&Px) ;
CA_VariantSet1DArray(&yVt, CAVT_DOUBLE,nombre,&Py) ;
CA_VariantSet1DArray(&zVt, CAVT_DOUBLE,nombre,&Pz) ;
CW3DGraphLib__DCWGraph3DPlot3DMesh(plotHandle,NULL,xVt,yVt,zVt,CA_DEFAULT_VAL);
but the curve doesn't appear...but I don't know why...
ciao ciao
Adeline
Message 5 of 13
(5,855 Views)
- In the samples provided with CVI you will notice some error checking. Your code does not check for any errors...
- In the samples provided with CVI the curves do appear, I have tried the samples yesterday before answering your question. Why don't you have a look at these samples?
Message 6 of 13
(5,846 Views)
yes, I have looked at this sample... that's why I don't understand...
I do as they did....on the same example...
Message 7 of 13
(5,841 Views)
Accepted by topic author adeline62
ok it's great I found what it didn't work!!
I had to add at some places :
CW3DGraphLib_CWPlots3DItem (plotsHandle, NULL, CA_VariantShort(1),&plotHandle);
CW3DGraphLib_CWPlot3DSetMultiPlot (plotHandle, NULL, VTRUE);
CW3DGraphLib_CWPlots3DItem (plotsHandle, NULL, CA_VariantShort(2),&plotHandle);
CW3DGraphLib_CWPlot3DSetMultiPlot (plotHandle, NULL, VFALSE);
ciao ciao
Adeline
Message 8 of 13
(5,834 Views)
I have the same problem, I used the following, but only the last drawing show up aftetr I finished. Do I need to add anything alse? Hope you can help me out.
 CW3DGraphLib_CWPlots3DItem (plotsHandle, NULL, CA_VariantInt(1), &plotHandle);
 CW3DGraphLib_CWPlot3DPlot3DSurface (plotHandle, NULL, xArray, yArray, dArray, CA_DEFAULT_VAL);
 for (i=0; i<k; i++)
     j=i+2;
     CA_VariantSet2DArray (&dArray, CAVT_DOUBLE, m, n, &cz[i]);
     CA_VariantSet1DArray (&xArray, CAVT_DOUBLE, m, &cx[i]);
     CA_VariantSet1DArray (&yArray, CAVT_DOUBLE, n, &cy[i]);
     CW3DGraphLib_CWPlots3DItem (plotsHandle, NULL, CA_VariantInt(j),&plotHandle);
Message 9 of 13
(5,652 Views)
hi!!
In fact, you draw graphs one by one...
I think you have to put that :
for each graph you don't draw
and for the graph you want to draw :
for example:
if you have 3 plots :
CW3DGraphLib_CWPlots3DItem (plotsHandle, NULL, CA_VariantInt(2), &plotHandle);
CW3DGraphLib_CWPlots3DItem (plotsHandle, NULL, CA_VariantInt(3), &plotHandle);
let me know if it works or not!!
bye
Adeline
Message 10 of 13
(5,563 Views)
