LabWindows/CVI
setCtrlAttribute
Checking SetCtrlAttribute:
  Hi..! I use the setCtrlAttribute to enable the timer. I often get the error called
  the attribute passed is not valid. What was the reason...?
  How can i check /verify whether all call backs are generated for all UI objects..?
Thanx and Regards,
Venki
(3,513 Views)
Woops...I got it..the order of the 'panel load' is not correct...
(3,511 Views)
