04-30-2010 10:02 PM
Hi, i am new . trying to figure out this VI codes. When i key in my gmail accout and run the program, i face the Error -1172 . I am not sure if i need to edit some SMTP server setting or the port setting. can any1 explain why i keep having this error?
thk in adv
05-01-2010 01:07 AM
this is the forum for CVI, not LabVIEW. You will get much better support in the appropriate forum. Good luck!
01-21-2011 12:38 AM
I hope this error due to the Proxy setting. you may need to set the proxy settings to communicate the smtp.
04-11-2019 05:10 AM
I also facing the same situation when I tried to sending email through Gmail error 1172 it shows an error iTunes sync error 54, so I really want a proper solution how to remove this error then please share with me.
