LabWindows/CVI
sample-by-sample continuous input and output using CVI
I'm using a PCI-MIO-16E-1 board with CVI ver 5.0 and NI-DAQ 6.9. Is there anyway whereby I can input a sample from the ADC, processed it in real-time, and output it to the DAC? The acquisition and wavefrom generation will have to be done at certain fixed frequency.
Using double-buffering and setting the half-buffer size to 1 (in order to capture just 1 sample), I always get a "no tranfer in progress" error for DAQ_DB_HalfReady. It seems that CVI or the NI card can't manage the intensive transfer of sample-by-sample. Is there any way to solve this problem? Thanks!
(2,898 Views)
Calvin;
The main problem there is not CVI either the NI DAQ boards, but Windows. Anything you run under Windows is not real time, either have a deterministic rate.
To have that sort of application, you will need to use our Real Time DAQ boards with Labview Real Time.
Hope this helps.
Filipe A.
(2,898 Views)
