LabWindows/CVI
runtime licence
I have been adding scripting support to my cvi app. To aid this I have created python bindings for the cvi runtime.
I have thought about releasing these bindings but am not sure if this would be allowed / encouraged.
The runtime is freely downloadable as is. However my bindings allow cvi development without the cvi development
environment.
Any advice would be appreciated.
Message 1 of 8
(5,608 Views)
I believe what you are suggesting would be in violation of our licensing agreement. Is there anyway you can prevent the development of CVI code in your application?
Sarah
Applications Engineer | National Instruments | UK & Ireland
Message 2 of 8
(5,560 Views)
Ok.
It was just a proof of concept.
I will use Gtk instead.
Message 3 of 8
(5,548 Views)
Actually Just to be sure is it also against the terms to call into one of your own dll's you create with cvi ?
ie I have an imageviewer dll that I created using cvi that I use in larger microscope application aquisition code can I
call into that dll with python or .Net pinvoke ? Or is that not allowed either or is calling directly into the cvi runtime the only dll I can not do that with ?
Message 4 of 8
(5,534 Views)
Making calls to a DLL should be fine. You would only be violating the licensing agreement if your tool allowed CVI development. DLLs made with the standard CVI package are freely distributable.
Sarah
Message 5 of 8
(5,532 Views)
Ok thanks that good enough for me.
Just to be clear we do own a copy of cvi.
PS.
I wont do this
but by the previous logic of allowing a dll you make yourself what would stop one making a thin dll wrapper around the runtime and then calling that dll at runtime.
Ie
My_ProcessMessages -> ProcessMessages
My_NewPanel -> NewPanel
etc ..
You don't need to answer that.
Thanks I will just call my imageviewer.dll that all the functionality I need.
Message 6 of 8
(5,527 Views)
Hello GlennPierce,
Thank you for being forthcoming on this issue.  An official response to your question is that the LabWindows/CVI Run-Time Engine is made available solely for the purpose of running executables or using DLLs created with the LabWindows/CVI development environment.  Use of the LabWindows/CVI Run-Time Engine with your Python bindings would be a violation of the Software License Agreement that is included in the LabWindows/CVI Run-Time Engine installer, and releasing such bindings would be illegal.  For reference, the Software License agreement can also be found at ni.com/legal.
Wendy L
LabWindows/CVI Developer Newsletter
Message 7 of 8
(5,477 Views)
Thanks for finding out the details.
I will find someother solution.
Message 8 of 8
(5,441 Views)
