LabWindows/CVI
return value == -6571 [0xffffe655]
Hi I succesfully generated a .NET Controller for an assembly written in C#.
The assembly isn't in the Global assembly cache, therefore I added the assembly with the function
CDotNetRegisterAssemblyPath in the automatically generated dotnetassemblyname.c Initialize function.
If I only call my the Initilize_...() and the Close_...() function in my main function everything is ok.
As soon as I add the entry function of the library (I got the docu) it compiles well, but during runtime I get:
NON-FATAL RUN-TIME ERROR:   "c:\...\TestPrograms\test\DotNetAdapter.c", line 1410, col 3, thread id 0x00000B38:   Function CDotNetInvokeGenericStaticMember: (return value == -6571 [0xffffe655]).
I know this is due to a wrong calling of the underlying function according to return values, but what to change to bring it back into business?
Here is my code:
void main(int argc, char **argv);
       static CDotNetHandle exception = 0;       // Exception handles für die DotNet Bibliothek
  // Muss aufgerufen werden bevor etwas aus der .NET Assembly aufgerufen werden kann
  Initialize_RmIntAdapter ();
  // startet und initialisiert die Bibliothek
  RmIntAdapter_RmIntAdapterCtrl_Start (&exception);
  // Schließt die Library wieder
  Close_RmIntAdapter ();
  exit(1);
I hope someone knows what to do now, I would appreciate it.
(3,064 Views)
perhaps answered here
NickB
(3,043 Views)
