LabWindows/CVI
resizing tab controls
Hi ,
is there any way to resize controls on a tab that is attached to a splitter when operating splitter (the mode "splitter sizes control" is selected).
Splitter only resizes tabs itself, not the controls on the tab. Some controls on the tab, for instance, are disappeared when splitter scale the tab down.
thanks for any help.
(4,147 Views)
> selected). Splitter only resizes tabs itself, not the controls on the
> splitter scale the tab down.   thanks for any help.
Associate a panel to that tab with GetPanelHandleFromTabPage()
Maybe that's enough for automatic resizes (which I don't use).
Otherwise:
Then give that panel a callback: SetPanelAttribute(Pnl,
ATTR_CALLBACK_FUNCTION_POINTER, cbp_Something);
Then within that function catch the EVENT_PANEL_SIZE event and do what you
want.
Guillaume Dargaud
http://www.gdargaud.net/
(4,142 Views)
Accepted by topic author sahin
One way to do it would be add a hidden splitter inside the tab panel you want to resize, then attach to this splitter all the controls inside the tab that you want to also move or size. Then, when the tab is resized, as a result of moving the original splitter, you can catch this event in the tab panel's callback and respond by moving the new splitter programmatically, using the OperateSplitter function, which should result in all the attached controls sizing or moving. You can see an example of this (although not inside a tab panel) in samples\userint\docking.cws.
Luis
(4,128 Views)
thanks
(4,120 Views)
