LabWindows/CVI
redeclaration error
All,
Don't quite understand why the compiler thinks there is a redeclaration in the following typedef:
typedef struct {
  int start_drop;
  int start_drop_limit;
  int max_internal;
  int min_internal;
  int end_level_range;
  int open_channel_avg;
  int end_level_value;
  int max_min_int;
  int max_length;
  int min_length;
} Fsa_Settings;
Here's the error message:
  "FSA_Settings.h"(39,15)   Redeclaration of 'Fsa_Settings'.
Suggestions appreciated.
Thanks in advance
(3,159 Views)
Ok, fixed it by adding..
#ifndef FLAG
#define FLAG
#endif
(3,157 Views)
