LabWindows/CVI
read typedef in binaryfile from cvi 8.0 / conversion from c++
// I have problems converting this code into cvi 8.0 - does anyone tried this before? Thanks in advance,
// kind regards, Martin Schmal
// working code in c++
#include "stdafx.h"
#include <iostream>
#include <fstream>
#include <cstdlib>
typedef struct MeasureHeader
  unsigned int  MeasureCount;
  char          LackNr[5];
  char          Karosse[3];
  unsigned char Ort;
  char          FileNamePart[19];
} t_MeasureHeader;
ifstream file("filname.dat", ios::binary);
file.seekg(0, ios_base::beg);                                                    //jump to begin of file
file.read( ( char* )&head, sizeof(t_MeasureHeader));
cout << head.MeasureCount << " Measuee Count " << head.Karosse << " Karosse Typ";
(3,437 Views)
Hi Martin,
the problem is, that LabWindows/CVI is an ANSI C compiler, not a C++ compiler. Have you already heard of Measurement Studio? It's an AddOn for Microsoft VisualStudio. This makes it possible for you to use C++ code as well (but still not within CVI).
Here are three links to the Measurement Studio Editions:
NI Measurement Studio Standard Edition:
http://sine.ni.com/nips/cds/view/p/lang/de/nid/1434
NI Measurement Studio Professional Edition
http://sine.ni.com/nips/cds/view/p/lang/de/nid/1413
NI Measurement Studio Enterprise Edition
http://sine.ni.com/nips/cds/view/p/lang/de/nid/2460
Hope this helps...
Daniel
NIG
(3,413 Views)
I finally found a way to read the binaryfile with ansi_c / cvi:
char *DATEI="test.001";  //init
typedef struct MeasureHeader {
  char          LackNr[5];
    char          Karosse[3];
    unsigned char Ort;
  } t_MeasureHeader;
FILE*file=NULL;
DATEI = (char *) malloc(1000);
 switch (event)
 case EVENT_COMMIT:
  GetProjectDir (&*DATEI);
  if (FileSelectPopup (&*DATEI, "*.001", "", "Data file to load", VAL_LOAD_BUTTON, 0, 0, 1, 0, DATEI) == VAL_NO_FILE_SELECTED)
 return 0;
  file=fopen(DATEI,"rb");
  fread(&head,sizeof(t_MeasureHeader),1,file);
  Count=head.MeasureCount;
  Lack=head.LackNr;
  Karo=head.Karosse;
  Ort=head.Ort;
  Dateiname=head.FileNamePart;
(3,382 Views)
