LabWindows/CVI
read Excel footer using excel 2000 api
 I want to read the excel right footer information.
I use Excel_GetProperty (ExcelWorksheetHandle, NULL, Excel_PageSetupRightFooter, CAVT_CSTRING, footerInfo);
this function gives me an error "This handle is invalid".
any suggestions?
(3,619 Views)
The worksheets handle does not validly represent an Excel worksheet page setup object. The flow needs to go as such: Get application handle, get workbooks handle, good workbook handle, get sheets handle, get sheet handle, get page setup handle, and then reference this page setup handle to get the footer property.
Consider this snippet:
error = Excel_NewApp (NULL, 1, LOCALE_NEUTRAL, 0, &ExcelAppHandle);
// Make app visible
error = Excel_SetProperty (ExcelAppHandle, NULL, Excel_AppVisible, CAVT_BOOL, VTRUE);
// Get Workbooks
error = Excel_GetProperty (ExcelAppHandle, NULL, Excel_AppWorkbooks, CAVT_OBJHANDLE, &ExcelWorkbooksHandle);
// Get Workbook
error = Excel_WorkbooksOpen (ExcelWorkbooksHandle, NULL, "C:\\test.xls", CA_DEFAULT_VAL, CA_DEFAULT_VAL,
                                          CA_DEFAULT_VAL, CA_DEFAULT_VAL, CA_DEFAULT_VAL, CA_DEFAULT_VAL, CA_DEFAULT_VAL,
                                          &ExcelWorkbookHandle);
// Get Active Workbook Sheets
error = Excel_GetProperty (ExcelAppHandle, NULL, Excel_AppSheets, CAVT_OBJHANDLE, &ExcelSheetsHandle);
// Get First Sheet
error = Excel_SheetsItem (ExcelSheetsHandle, NULL, CA_VariantInt(1), &ExcelWorksheetHandle);
// Get page setup object
error = Excel_GetProperty (ExcelWorksheetHandle, NULL, Excel_WorksheetPageSetup, CAVT_OBJHANDLE, &pageSetup);
// Get right footer information
error = Excel_GetProperty (pageSetup, NULL, Excel_PageSetupRightFooter, CAVT_CSTRING, &footerInfo);
SetCtrlVal (panelHandle, PANEL_STRING, footerInfo);
// Check for ActiveX errors
CA_GetAutomationErrorString (error, errorCode, 256);
Hope this helps!
Evan Prothro
RF Systems Engineer | NI
(3,587 Views)
thanks for the answer, it worked
(3,533 Views)
