Project works fine on PC#1. When I try to open it on PC#2, I get "Unable to open project - File not found" error. But which file is not found? Who knows, the error does not report it! Did you guys have some Microsoft programmers working on this?
Anyway, I opened the project file up in an editor, and verified that every file referenced in the project is on PC#2. I am using the exact same project, directory structure and source files, transferred thru our network. Everthing this project references is installed in the same directory on both PC's - Measurment Studio, CVI, NIDAQ, NIDNET - all the same versions. The executable created on PC#1 will run on PC#2! But I really need to be able to run the proje
ct there. I have attached the project file below for reference.
