LabWindows/CVI
quit button
Hello everybody !
I have to create a quit button to quit my program! I have a start button too. However, the program run when I put on Quit Button once and when I put twice it quit the program. When I put Start Button nothing happens even if my main code is into.
My code of Quit Button is :
int CVICALLBACK QuitCallback (int panel, int control, int event,  void *callbackData, int eventData1, int eventData2)
    switch (event)
        case EVENT_COMMIT:
            QuitUserInterface(0);
            break;
        case EVENT_RIGHT_CLICK:
            break;
    return 0;
Can I have help? Why my QuitCallback button do that ?
(5,538 Views)
It is difficult to say what's happening without looking at the entire code: the quit callback looks correct, that must be some other reason for this behaviour.
Is the program multithreaded? Is it operating a long-lasting function while you press the quit button the first time? Is there one RunUserInterface only in the program?
(5,537 Views)
I have a RunUserInterface() on my timer if I put this function on my start button it will work in your opinion?
(5,532 Views)
That looks strange to me: the recommended structure of a CVI program has no RunUserInterface inside control callbacks!
Look at some of the examples that ship with CVI for examples of a regular CVI framework.
Can you post your code?
(5,529 Views)
int CVICALLBACK StartMot (int panel, int control, int event, void *callbackData, int eventData1, int eventData2)
    switch (event)
        case EVENT_COMMIT:
        int i;
        ComWrt(1,"\r",StringLength("\r"));
        for(i=1;i<360;i++)
            /* begin the rotation */
            ComWrt(1,"SK(i)",StringLength("SK(i)"));
            /* stop the measure */
             ComWrt(1,"CP(i)",StringLength("CP(i)"));
            break;
        GetCtrlVal(panelHandle,PANEL_intervalTimer,&IntervalTimer);
        return 0;
    return 0;
int CVICALLBACK ActiveTimer (int panel, int control, int event, void *callbackData, int eventData1, int eventData2)
    switch (event)
        case EVENT_COMMIT:
            //ResetTimer(0,0);
            RunUserInterface();
            ResumeTimerCallbacks();
            SetCtrlAttribute(panelHandle,PANEL_TIMER,ATTR_ENABLED,1);
            break;
            break;
    return 0;
This is my code.
So, you think I should delete RunUserInterface ?
(5,524 Views)
Of course you need to!
And there's a lot of mistakes in your code, I don't even know where to start with!
First of all, what's the purpose of the timer?
And why putting ResumeTimerCallbacks and SetCtrlAttribute (...ATTR_ENABLED)inside the timer callback? If the timer were not enable or suspended the callback won't even fire!
You should seriously consider taking some basic cource on CVI: NI offers both frontal and online courses on the product: see Customer Education page for reference. At least you should run through the tutorial that gets installed on your machine.
(5,519 Views)
I found the solution ! it wasn't the quit button
(5,484 Views)
