LabWindows/CVI
protection error
大家好,
我使用的是LabVIEW2009跟BCB6.0。主要是BCB呼叫LabVIEW2009產生的DLL檔案,回傳數值判斷正確性。
可是在Load DLL的時候發生了 Protection Error的問題。問題內容詳細在附件圖檔中。
而這個DLL檔主要是LED辨識的功能,有使用到NI-Vision Acquisition這些軟體。
不知道這些軟體是否有限制,在BCB環境下呼叫DLL時說有偵測到 WinIce SoftIce這些Debugger軟體在運作,就無法執行。
因為我有另外作一個VI,內容只有兩數相加回傳和的DLL檔。這個DLL檔呼叫就很正常,也有數值回傳。
所以才想問是否有限制嗎?
(4,092 Views)
Translation
I am using LabVIEW2009 with BCB6.0. BCB call LabVIEW2009 mainly generated DLL file judicious of return values.
But in the Load DLL when the problem occurred Protection Error. Asked questions in detail in the image file in the attachment.
DLL file and this is mainly LED identification features, are used to the NI-Vision Acquisition of these programs.
Do not know whether the software is limited, call DLL in the BCB environment, she said that these Debugger detected WinIce SoftIce software in operation, it can not be implemented.
(4,089 Views)
See this
and How Can I Programmatically Disable Protection Error Dialog in LabWindows/CVI?
(4,088 Views)
Also see this [broken link removed]
(4,083 Views)
To muks
Thanks for your kindly help, i will research this documents and reposed to forum.
(4,079 Views)
