LabWindows/CVI
propreitary protocol information
Hi..!
  I need a help to analyse the protocol to transfer a binary file from the host to the
target system. I connected the rs 232 to uSB converter and i monitor the data flow
using the USB monitor.Some of the aspects i dont understand from my observation.
  1) What is mean by 'value'in the file 'sample.txt'..?
  2) How can i send the request using CVI from the host to target..?
  3) When i trasfer the file called dummy.dld how can can read the file with out
corrupting the file formate..?
  4) what is mean by pipe handle..?
  5) I miss something from the following code to write the file named dummy in
     to the comport....
  6) What are the interupt handlers do?
  7) My protocol works similar like Hyperterminal 1K x-modem protocol....
     but using this protocol i could transfer the file size more than 276 kb...
  😎 So is there any example which demonstrates the x modem protocol..?
Thanx and regards,
Venki.
#include <rs232.h>
#include <formatio.h>
#include <utility.h>
#include <ansi_c.h>
#include <cvirte.h>
int main (int argc, char *argv[])
 int  fH = 0;
 int  i, br;
 unsigned char msg[256];
 int counter=0;
 char buffer[1500];
 //FILE *fH = NULL;
 if (InitCVIRTE (0, argv, 0) == 0)
  return -1;    /* out of memory */
 OpenComConfig (4, "COM4", 38400, 0, 8, 1, 512, 512);
 fH = OpenFile ("dummy.dld", VAL_READ_ONLY, VAL_OPEN_AS_IS, VAL_BINARY);
       //Delay(2);
       while((br=ReadFile(fH,buffer,1))<1024){
   //printf("%s","Test String");
   //Delay(5);
  //printf("%d\n",counter);
     if(counter==276){
     // break;
     counter++;
     ComWrt(4,buffer,1024);
     // printf("%d",br);
     Delay(0.5);
    //printf("%d",fH);
 //ComFromFile (4, fH, 0, -1);
 Delay (0.2);
 br = GetInQLen (4);
 DebugPrintf ("Bytes at port 4: %d\n", br);
 ComRd (4, msg, br);
 CloseCom (4);
 if (fH > -1) CloseFile(fH);
 return 0;
(3,283 Views)
(3,276 Views)
As i could't attach the .dld extension i changed to txt formate....
(3,277 Views)
hello venki,
which program do you exactly use to monitor the traffic?
which target do you try to access?
which request do you want to send?
can you describe the application a bit further?
regards,
robert h
ni germany
(3,207 Views)
