LabWindows/CVI
project tree won't autohide when uir editor is being used
CVI 2009 won't autohide the project tree when you clik inside the uir edit panel.
When you click inside any of the text-based edit panels the project tree, if it's showing, will collpase (hide).
Menchar
(3,412 Views)
Hi Menchar,
I just tried it and have to confirm your observation. I would call it a little bug and hope that NI files a corrective action 🙂
Until then, there is a little trick to manually obtain a hidden project tree, provided that you are using several tabs... you can switch to a text tab, and then switch back to your UIR tab... this involves two mouse clicks instead of one.
Have a nice day,
Wolfgang
(3,403 Views)
Thanks, guys. This wasn't yet known. Filed as #218979.
Luis
(3,390 Views)
It is a nit but then again the next time NI takes a sweep through the code for a revision they know about it and can easily fix it I should think - it is an annoyance - I've really gotten used to the autohide.
There was another nit on the uir editor I found in 9.0 - soemthing to do with the uir panel coming to the foreground when doing somehting else, compiling I think.  May be related.
(3,383 Views)
