LabWindows/CVI
programming ni6520
Has anyone had experience in programming the NI-6520 Relay card using CVI?  I am using CVI 2013 with DAQ 15.0.
NI-MAX shows the card installed and can access it via the Test Panel.
I just need some simple command lines for flipping the relays.
(5,272 Views)
Hey jbrown60,
Have you already tried the examples that ship with CVI?
Text Based NI-DAQmx Data Acquisition Examples - http://www.ni.com/example/6999/en/#.NETDIO
in that document it states that "The default installation directory for LabWindows/CVI examples is C:\Documents and Settings\All Users\Documents\National Instruments\CVI\samples\DAQmx."
Also check out the support reasources!
NI LabWindows™/CVI Technical Resources: Getting Started, Support, and Downloads - http://www.ni.com/lwcvi/technical-resources/
JY
Application Engineer, RF and Communications
(5,248 Views)
My installation of CVI did not come with the samples in that directory.
The problem is slightly more complicated in that my develoment machine is a laptop and the target machine is a desktop with the 6520 in it, so I am programming blind.
I have installed the NI-DAQ 15 that came with the card on both machines (which hopefully won't screw up previous development packages).
The desktop sees the NI-6520 as "Dev1".  On the test panel: I can select port 1, and select the state under port1/line0:7 to change the state of relays. So I know I should be able to talk to it somehow. Is the board considered a switch or digital I/O.  I'm just looking for maybe ten lines of code that will connect me to the board and activate a relay.
(5,197 Views)
1. A correct install of DAQmx should come together with the appropriate examples, maybe located in a different folder on disk. You can use the example finder (Help >> Find examples... menu item in CVI IDE) limiting the search on your specific board: see this post where I explain how to do this
2. Even if your PC hasn't the correct hardware installed, you could create a simulated device for your board and test your software agains it: see this tutorial on simulated deviced in DAQmx
(5,178 Views)
Thank you Roberto for directing me to some very useful information.
Using the Help files for the NI MAX install I was able to create a virtual instrument.
I was also able to find the CVI example program "WriteDigPort" which sets up a DAQmx task to write to the board, which in this case is the 6520.
As expected it really comes down to only about 6 lines of code.  I will post the controlling function when I get it incorporated so that others may not have to spend days hunting.
(5,159 Views)
You're welcome!
(5,154 Views)
Accepted by topic author jbrown60
As promised. A simple set of routines to control the 6520 under Win7, CVI 2013, NI-DAQmx 15.5
Required include files:
#include <NIDAQmx.h>
#include <DAQmxIOctrl.h>
/* declare global for Task Session */
static TaskHandle taskHandle = 0;
/* main function calls Init6520Sesn to get taskHandle and start DAQ task */
int Init6520Sesn( )
   int32 rtnStatus = 0;
   char chan[256];
 /* NI MAX address location for the 6520 shows as Dev1,
 * port0 controls sensors, port1 controls relay state
 * line0:7 addresses the 8 relays on the board
   sprintf(chan,"Dev1/port1/line0:7");
   // DAQmx Configure Code
   rtnStatus = DAQmxCreateTask("",&taskHandle);
   rtnStatus = DAQmxCreateDOChan(taskHandle, chan, "", DAQmx_Val_ChanForAllLines);
   // DAQmx Start Code
   rtnStatus = DAQmxStartTask(taskHandle);
   /* put error handling code here */
   return 0;
void Switch6520Relays(int nRelayState )
   uInt32      data;
   char        errBuff[2048]={'\0'};
   int32  written;
   // DAQmx Write Code
   data = nRelayState ; // convert int to UINT32
   rtnStatus = DAQmxWriteDigitalU32(taskHandle,1,1,10.0,DAQmx_Val_GroupByChannel,&data,&written,NULL);
   if(rtnStatus != 0)
      DAQmxGetExtendedErrorInfo(errBuff,2048);
      MessagePopup("DAQmx Error",errBuff);
// END 6520 Functions
/* Add shutdown calls when session no longer needed, in this case when the application closes */
int CVICALLBACK panelCB (int panel, int event, void *callbackData,
  int eventData1, int eventData2)
   if (event == EVENT_CLOSE)
      DAQmxStopTask(taskHandle);
      DAQmxClearTask(taskHandle);
      QuitUserInterface (0);
   return 0;
(5,118 Views)
