LabWindows/CVI
programmatically delete items in ring control
Good morning
How to delete all the items in menu ring when i start the program(the list should be empty)
(4,022 Views)
ClearListCtrl() or DeleteListItem()
(4,016 Views)
Normally CVI ring controls are empty at program start, unless you have manually added some elements in the UIR editor that you may want to delete in the IDE. In any case cdk suggestions are the programmatic way of clearing the list any time you want iin your program.
(4,001 Views)
Thanks Roberto and cdk
(3,997 Views)
Veeru wrote:
Good morning
In case you are programming it with LabVIEW you can pass an empty array of string to the property Strings [] of the ring.
(3,989 Views)
