LabWindows/CVI
programing PXI-6509
Hi;
I must do a high level function to write/read a DIO PXI-6509 port
I am using NIDAQmx library functions as low level functions.
The question is, what is the better way to do this?
option1:
<pseudocode>
high_level_function()
1.DAQmxCreateTask
2.DAQmxCreateDOChan / DAQmxCreateDIChan
3.DAQmxStartTask
4.DAQmxWriteDigitalU8 / DAQmxReadDigitalU8
5.DAQmxStopTask
6.DAQmxClearTask
So, in this option everytime you call this function, you have to do all the low level functions
option2:
<pseudocode>
high_level_function_1()
1.DAQmxCreateTask
3.DAQmxStartTask
high_level_function_2(taskHandle)
1.DAQmxWriteDigitalU8 / DAQmxReadDigitalU8
high_level_function_3()
1.DAQmxStopTask
2.DAQmxClearTask
So, in this option the task remaind created while the program are running,
and I have tu use global variable (TaskHandle myTaskHandle) because of high_level_function_2 have it as parameter
and I have to use this function in another file.c of the project.
I hope to be enough clear.
any suggestions?
(4,156 Views)
Norak
I have used option 2 for a silimar requirement.  To limit the scope of the global (and hide all of the excessive overhead that NIDAQmx requires for simple functions) place the functions in a seperate c file  or build the functions into a DLL.
Option 2 is also my recomendation because it is only a single task that is running continousally the valules on the output ports will remain constant  i do not beleve that the valules written to the port will remain constant when the NIDAQmx task is closed.
Colin
(4,146 Views)
thanks for your replay.
I check that if the task finish the DIO set remain in its state...
(4,139 Views)
