LabWindows/CVI
program crash
Good morning,
I am developing a program that converts dxf files to ISO format for CNC.
The program, in debug mode, works.
When I run the program in release mode, it crashes; the behaviour is completely different.
I think that it could be a memory allocation problem;
is there in CVI a different memory management in debug and release mode?
how can I fix the problem?
I use CVI7.1 (a very old version...).
I use variable like these: as you can understand it is like a matrioska...
typedef  struct
    DXF_block  *blocks;
    DXF_entity *entities;
} DXF
typedef struct
} DXF_block;
// Entità
typedef struct
    float *x;                        // array con le coordinate x
    float *y;                        // array con le coordinate y
} DXF_entity;
Any suggesion?
Than you a lot, Paolo
Message 1 of 1
(2,878 Views)
