LabWindows/CVI
problems with external dll
I everybody,
I'm trying to control an instrument (Bayspec wavecapture, FBG interrogator) by means of Labwindows 9.0. I have the SDK provided from Bayspec, which consists of a library .lib file, a .dll file and an header .h file. I added the .lib and .h files to the project, put the .dll file in the same project directory, and write a minimal code to try to open and close the device. After compilation I received a lot of errors, some of that I solved "empirically": problems with the types WORD, BYTE, LPCSTR, which I solved by adding into the header file:
#define WORD int
#define BYTE char
#define LPCSTR const char (but probably should be const char*)
function missing prototypes error, which I solved by specifing into the function definition the void type, i.e.:
DLL_PORT_TYPE    BOOL  DLL_PORT_FUNCTION_TYPE DLL_Open_Device(void);
instead of
DLL_PORT_TYPE    BOOL  DLL_PORT_FUNCTION_TYPE DLL_Open_Device();
After that I was able to compile without any error or warning, but when I build everything I have the following project link error:
Undefined symbol '_DLL_Open_Device@0' referenced in "bayspec_2.c".
I suppose the dll was realized with/for visual c++ 6.
The first lines of the .h file are the following:
#ifndef _Sense2020DLL_
#define _Sense2020DLL_
//difine the export type
#define DLL_PORT_TYPE __declspec(dllexport)
#define DLL_PORT_FUNCTION_TYPE __stdcall    //this can be used in visual basic program
I feel that in that lines could be located the problem, but I'm a newbie programmer.
Thanks a lot if you can help me and sorry if the solution was into the official documentation because I was unable to found it.
Cosimo
(4,145 Views)
Hey Cosimo,
Did you take a look to this document?
"Undefined Symbol" When Building a Stand-alone Executable in LabWindows/CVI
Let me know if it works.
Best regards
Matteo
(4,114 Views)
Thank you Matteo,
I looked at the target settings (Labwindows 9.0) but the Run-time support is set to Full run-time engine. I try to check the "Enable load external module" option too, but it didn't work. A strange think because I can open the same Dll in Labview without any problem. I look inside the dll with dependency walker and I see all the functions. I solved all the problems with the definitions into the header file by adding windows.h, but not more.
I will live with the idea of work with Labview!?
Thanks again for your kind answer,
Cosimo
(4,104 Views)
For my research work, can any body share me the files .dll, .lib, .h given by BAYSPEC. If anybody does this, I will be greatfull to him forever.
(3,825 Views)
Hi Badal,
I would suggest to you to open a new thread on the NI Forum. This would allow you to submit your topic to a very large community instead of continuing an old post with very low visibility. By the way a took a look on the instrument driver network and I din't get any feedback about the istrument you are looking for. So it might be useful for you to ask to the Bayspec if they provide for some LabWindows/CVI(?) instrument driver.
Good luck for your search and have a great day.
Matteo
(3,821 Views)
